papagray1505
Sep 15, 2022Follower
outdoor cctv to hedgehog camera inside feeder station how to connect to house wifi
hi
we regular feed the wildlife but we are investing in a specific animal friendly cctv camera for inside new feeder station, alas i made a mistake and purchased a non wifi camera but a poe camera can supply power okay but not keen on drilling through walls into living room to connect network cable, have a very strong wifi signal outside would it work if i plugged in a Netgear ex6120, attached permanently a network feed from the camera into the plug itself ?
cheers
1 Reply
Yes and no.
It'll work in that the ethernet connection will work. But the EX6120 doesn't have POE so you'd have to have a POE injector as well if the camera is POE powered.
