Frmtrkr
Oct 15, 2018Follower
Password incorrect Nighthawk MR1100
Cannot get nighthawk to recognize pass word. To access any part of app or netgear dashboard i need to factory reset then apply new password. This password works one time on one iphone and will not wo...
AliasRat
Oct 23, 2018Tutor
Did you manage to log in on one device and then update the password after resetting to factory defaults?
Does it then not accept the new password created nor the factory default password?
If you've reset it with one device (like your iPhone) try changing the password in the web interface from a computer instead and check if it persists when using the web interface or mobile app thereafter?
