rpforadori279's avatar
Dec 20, 2022
Please advise
Moving to top of a mountain in Luray Va and need a technical solution for best possible download ability. My friends us a Netgear Nighthawk Hotspot for personal use, I work full time as remote software support and I need to download datasets, 30-40 gig routinely. Is their a high speed solution?
1 Reply
  • plemans's avatar
    You'd have to check with your local ISP supplies on what speeds/data caps they support. the device isn't the main issue. Its what can be supplied for that area.
