Drester
Apr 15, 2019Follower
Poor cellular signal fix
I have Poor to Fair signal strength on my new Nighthawk mobile router.
5 bars on ipads and cell phones.
Has anyone found the best cellular signal booster antennas out there for this devi...
Blanca_O
Apr 21, 2019NETGEAR Employee Retired
Hi Drester
Welcome to NETGEAR Community!
If the reception/signal is low then we suggest moving the device to a location with clear view of the sky or consider purchasing/using external antenna.
You can check this link for antenna suggestion.
Blanca
Community Team
