Gcaussie
Jan 08, 2021Aspirant
Poor range - router solution?
Hi I've purchased a nighthawk from Telstra in Australia. It was sold as a companion modem/router for their 5g service but honestly it has really poor wifi range. This is probably to be expected, I th...
michaelkenward
Jan 08, 2021Guru - Experienced User
A Nighthawk what? "M5" isn't a model number that I recognise or that I can find here.
Netgear calls it the M5 but its actual model number is MR5200.
https://www.netgear.com/home/mobile-wifi/hotspots/mr5200
the Mr5200 has ethernet out so you can connect another router to it (in access point mode) to provide better wifi coverage if you'd like.
- GcaussieJan 08, 2021Aspirant
Thanks for that - yes I assumed I'm going to need a router to extend wifi range - the question then is - is there a reccomended router?
I've seen some comments from people using these they they had poor speeds when connected to their existing router due to some intereference or other unknown reason.
plemans wrote:Netgear calls it the M5 but its actual model number is MR5200.
- plemansJan 08, 2021Guru - Experienced User
Gcaussie wrote:Thanks for that - yes I assumed I'm going to need a router to extend wifi range - the question then is - is there a reccomended router?
I
Basically what hits the points you want. You can either run the router in access point mode and make sure the wireless channels are on a different one's than the hotspot or put the hotspot in passthrough mode.
- michaelkenwardFeb 03, 2021Guru - Experienced User
If all you want is an access point, buying an extender and using it an AP mode might be better.
Folks here report that routers in AP mode are less effective than purpose built extenders. After all in AP mode a router loses many of the reasons for buying one.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
Alternatively, see if it is possible to use the MR5200 in modem only (bridge) mode. The manual is not promising on that front though.
For help in choosing what to buy, start at the production pages and feed in your needs and the size of your spread.
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
