MOHAMED1992
Jun 15, 2019Follower
Poor WiFi signal
Why WiFi signal is weak is there setting to adjustment signal?! Or there’s problem in my device!?
Jun 15, 2019Guru - Experienced User
Would need way more info than what you provided to help you or determine these issues.
1. What router are you using? Firmware on it?
2. What speeds do you pay for? What speeds do you get over a hardwired connection? Speeds over wifi in the same room with the router?
3. How large is your house?
4. Building materials in your house?
5. What devices are you testing with? wireless in them?
