lxericb
Jun 12, 2023Aspirant
port ethernet Nighthawk M5 5G MR5200
Hi, it seems that the ethernet port on this router only provides Internet to the 5G router. Is it possible to do the opposite, i.e. have the 5G router provide Internet to a network via this Ethe...
Jun 12, 2023Guru - Experienced User
What are you connecting it to?
You can usually put it in passthrough mode if you're connecting another router to it.
there's a user manual here: https://www.netgear.com/support/product/mr5200
