lxericb
Jun 12, 2023Aspirant
port ethernet Nighthawk M5 5G MR5200
Hi, it seems that the ethernet port on this router only provides Internet to the 5G router. Is it possible to do the opposite, i.e. have the 5G router provide Internet to a network via this Ethe...
JohnPeng
Jun 13, 2023NETGEAR Expert
Could you please detail what you would like to achieve?
1. You can connect a WiFi router or Mesh System to the ethernet port. M5 will provide the 5G data to your WiFi router or Mesh system
2. You can connect the ethernet port of M5 to the modem of your home network and enable ethernet offloading. The data will go through your home internet. If your home internet is down, the M5 will continue to provide the data connection to its' clients using 5G data.
Thanks
lxericb
Jun 13, 2023Aspirant
Hi,
We would like to connect the M5 ethernet port to a WAN port on a router / Firewall.
In any cases only the M5 will provide the Internet.
On the LAN port of the router / firewall are connected a few computers with no Wifi card, only ethernet cards
And we would like that this computers will receive the internet from the M5
Best Rgds
