rookie_says_hi's avatar
Mar 02, 2021
Port Forwarding - Error Adding Entry
Encountered the error message: "Error Adding Entry" when trying to add an entry under Port Forwarding. Not sure what I'm missing here. Did search on the forum, found 2 similar cases but didn't see how it was resolved. And key difference being my scenario can't even add an entry.
Any help is much appreciated. Thanks!
NightHawk M1
Hardware Version: 1.0
Firmware/Bootloader Version: NTG9X50C_12.06.12.00
Firmware Build Date: 2020/04/26
Using TPG Singapore 4G/LTE SIM.
IP Passthrough: ON
DHCP: OFF
Ethernet Standby: Disabled
DMZ: Enabled
No RepliesBe the first to reply
