kevinpaynter
May 22, 2019Follower
Port Forwarding Not working
I have recently purchased a Nighthawk M1 and this replaces my existing netgear router. The software with router has a port forwding area which I have openned however whenI check it is ...
ArodiD
Jun 26, 2019NETGEAR Expert
Hi kevinpaynter ,
The IP address that is showing in your screenshot looks to be a NAT'd IP from memory which will block ports from the network side.
Can you check the APN settings on your old router to see if it matches with the MR1100. I suspect your old router APN profile might be telstra.extranet and the APN profile used on your new router is telstra.internet. If so, then create a new APN profile with telstra.extranet on the MR1100 and set it to be the default profile and it should start working for you.
Arodi
Community Team
