DeaconJoe
Jul 02, 2019Aspirant
Power adapter
I plan to bring an Ac1750 router to the Democratic Republic of the Congo to set up for a clinic. Their power is 220 V, 50 Hz. I know I will need a plug adapter. Do I also need a voltage adapter for the roter's power adapter or is it switchable for different voltage?
I don't have the adapter for this specific product but if you look at the one you have, it should list the voltage range and hrz on the label for the power supply. All the ones I have list this.
- DeaconJoeAspirant
Thanks. But I purchased a new unit and don't want to open the box to check the adapter in case I need to return it.
- DeaconJoeAspirantThanks. for the info and the possible concerns. At this point, I am going to go with it. They should be able to at least network computers with it until they get internet access.
