intofx
Apr 16, 2018Guide
Pre April Nighthawk and band 14 and 46
Will the pre April 2018 - version 6112B - AT&T Nighthawk get bands 14 and 46 enabled via firmware? I see that hardware is the same as the newer 6420B version. I just bought a new hotspot but it...
- Apr 19, 2018
It seems like there is some confusion here about the models of AT&T M1 Nighthawk LTE Mobile Hotspot Router. So I will try and explain the different SKU and the differences between them.
Netgear has 4 SKUs for AT&T M1 and they are: MR1100-1A1NAS, MR1100ABS-1A1NAS, MR1100-2A1NAS and MR1100ABS-2A1NAS.
Main Consumer SKU
AT&T Business SKU
Main Consumer SKU
AT&T Business SKU
Netgear SKU ID
MR1100-1A1NAS
MR1100ABS-1A1NAS
MR1100-2A1NAS
MR1100ABS-2A1NAS
WPS
Supported
Not Supported
Supported
Not Supported
USB tether
Supported
Not Supported
Supported
Not Supported
Ethernet tether
Supported
Not Supported
Supported
Not Supported
Ethernet Offloading
Supported & Disabled
Supported & Enabled
Supported & Enabled
USB thumb drive and SD Card
Supported
Not Supported
Supported
Not Supported
1500/1430 byte MTU selection dropdown box
Not Supported
Supported & 1430
Not Supported
Supported & 1430
Band 14
Not Supported
Not Supported
Supported
Supported
Also the AT&T M1 does not support B46 only B14 was added to the 2A1NAS SKUs there will be no firmware updates available for 1A1NAS to support B14. The B14 needed hardware change to support FirstNet B14 properly that is why HW was changed. So I am pretty sure going forward the all the new units Netgear ships will be the 2A1NAS SKU units.
JasonN
Apr 18, 2018NETGEAR Employee Retired
Hi intofx,
The MR1100 (AT&T model) supports bands listed below:
• LTE AT&T Bands: B2, B4, B5, B12, B29, and B30
• LTE Roaming Bands: B1, B3 and B7
Please let me know if you have any other questions. :]
- Jason N
- intofxApr 18, 2018Guide
Hey Jason
Thanks for the reply, I'm still confused. You say the AT&T MR1100 but there are two different supplier code numbers. 6112B and the new 6420B
AT&T updated their website with new specs that include band 14 and the different model number 6420B. You can view it on the AT&T page under specs > wireless technology. https://www.att.com/devices/netgear/nighthawk-lte-mobile-hotspot-router.html#sku=sku8820339
Are saying this is incorrect info? or that model 6112B will not have band 14? even though it has the same hardware inside
- JSchnee21Apr 19, 2018Virtuoso
Hi intofx,
Great question. I'm in a similar boat. If you look up the publically available FCC info, it's clear that it is possible to enable at least band 14 via a firmware update. I had seen a similar set of documents regarding band 46 as well -- though these seem to have mysteriously disappeared. Since band 14 is in the 700MHz-800MHz the existing antenna's should cover it. I'm less familiar with band 46 (LAA). This seems to just be 5.8GHz Wifi carrying LTE packets instead of Ethernet packets -- so I guess the Wifi antennas would receive this? No idea.
BUT, whether AT&T/Netgear will choose to release a firmware update which grants Gen1 units one or both of these capabilities is anyone's guess.
Wish I could be more help, but I'm an end user like you. You could try returning and replacing your unit -- but unless the inventory is clearly marked, this is liable to be error prone as vendors work through existing stock.
-Jonathan
- ErnestTheGreatApr 19, 2018NETGEAR Employee Retired
Main Consumer SKU
AT&T Business SKU
Main Consumer SKU
AT&T Business SKU
Netgear SKU ID
MR1100-1A1NAS
MR1100ABS-1A1NAS
MR1100-2A1NAS
MR1100ABS-2A1NAS
WPS
Supported
Not Supported
Supported
Not Supported
USB tether
Supported
Not Supported
Supported
Not Supported
Ethernet tether
Supported
Not Supported
Supported
Not Supported
Ethernet Offloading
Supported & Enabled
Supported & Enabled
Supported
Not Supported
Supported
Not Supported
Not Supported
Supported & 1430
Not Supported
Supported & 1430
Band 14
Not Supported
Not Supported
Supported
Supported
