MVS2's avatar
MVS2
Follower
Sep 19, 2019
problem getting unlocked mr1100 to connect att
Trying out a new internet reseller and wanting to use router #2 with that reseller.
Details:
Reseller #1 :  Sent router #1 with ATT SIM card installed.  Works fine.
Reseller #2:  Allows BYOD, sent SIM card with their logo (not ATT)
Router #1 - MR1100 -  on start up shows the ATT logo, assume is an ATT version
Router #2 - MR1100 -  bought from Amazon, "unlocked" per the listing.
After login to admin, every single setting and check box is set to exactly the same on both routers
Router #1 will connect to LTE with either SIM card
Router #2 will not connect with either SIM
Is there something else I can try or is this a bad router?
Thanks
1 Reply
  • What model is this router#2? you can check on the back label after removed the battery and back cover, not every M1 (aka MR1100) model supports all the LTE bands in every country.
