imsarsehus
Sep 10, 2021Star
problem signal searching after upgrade latest firmware on m2 nighthawk
hi, i am from malaysia and i use m2 nighthawk telstra , my problem is when i upgrade new firmware NTGX24_10.17.10.00, signal just searching and no network found, and appear on screen mobile broadband...
michaelkenward
Sep 11, 2021Guru - Experienced User
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
