HunterHunter
Nov 20, 2019Aspirant
Problem with Firmware update
Hi all, I am facing a problem while upgrading my netgear MR1100 router to the latest firmware. I have downloaded the latest firmware from netgear website and logged into the router web application t...
Blanca_O
Nov 20, 2019NETGEAR Employee Retired
Hi HunterHunter
Welcome to NETGEAR Community!
Please remove the SIM card, turn the device, access the router settings page and re-load the firmware. Once completed, re-insert the SIM card .
Blanca
Community Team
HunterHunter
Nov 21, 2019Aspirant
Hi Blanca_O :
Thanks for your quick reply. The device is stuck into the same state of trying to update the device it is not even booting and the progress bar is not moving. I have no access the web application anymore. I can't hardreset it (nothing will happened), the router screen only shows "Updating device, Please do not power off". I tried to press the power button for 10 seconds the router led blinks (Red, Blue) for a while then a new message appears on the router screen which says: "Downloading software update" but the router is not connecting to the internet. Any advice about this matter will be helpful.
- HunterHunterNov 21, 2019Aspirant
Is it possible to reflash/upgrade firmware of Netgear MR1100 via usb cable? I can't ping the device and couldn't use TFTP client to upload a new firmware. What can I do in such situation?
- 1668880Nov 22, 2019Aspirant
Same thing happened to mine. Had to call Netgear and get a replacement.
- Blanca_ONov 25, 2019NETGEAR Employee Retired
Hi HunterHunter
This appears to be a hardware issue and needs to be replaced.
Blanca
Community Team
