Miguelchr
Jul 11, 2019Aspirant
Problem with LB1120
Hi i am having the same problems as in this post: https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Problem-with-LB1120/td-p/1561713 But in the post there is no fix to the prob...
ArodiD
Jul 12, 2019NETGEAR Expert
Hi Miguelchr ,
Can you please try holding the factory reset button longer than 5 seconds? Stop pressing when you see a change in the LED's.
Arodi
Community Team
Miguelchr
Jul 12, 2019Aspirant
Hi Arodi i did a few tries holding the reset button for around 1 minute but still the modem does not change his led status red/on/off/on/off
Thanks for the reply
