alihill381's avatar
alihill381
Follower
Feb 10, 2020
Problem with Netgear 6000450 MIMO Antenna
HI
If I connect Netgear 6000450 MIMO Antenna on MR1100 EUR ( without battery )
MR1100 Directly reboot every 1 min
I need to plug-in battery then connect Netgear 6000450 MIMO Antenna again (Working fine)
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Thanks for the information. We will check the use case and get back to you.
    Regards
