Alpin39
Jan 28, 2025Follower
Problem with Nighthawk M1 USB Port
I reactivate my Nighthawk M1 and after one week, i could not charge anymore Is there any charger for the Akku or how can it happen, that the usb-C Port is down now? Can I fix this? thanks
rcpax
Jan 29, 2025Luminary
i have heard of instances of the nighthawk usb-c port going bad. I'm not sure how it happens but it never happened to me. Make sure you try different OEM phone cables and try several charging bricks as well. I have successfully used the One Plus red cable and fast charging brick on an M6. If the port is truly bad, you could certainly try getting it replaced by somebody who works with phone repair.
