Trog101's avatar
Trog101
Problems MR2100
Hi,
Purchased a NH MR2100 through Telstra in Australia ,
Device has the following issues.Randomly wont turn on  from a recharge to a general turn on running off battery( although the blue on light is lit ) only way is to remove battery .
Loses its login and password : multiple times I have had to reconfigure all devices to new credentials
Local Telstra shop claims this device has no known issues and will have to send it back if my problems  persist.
Cheers
Trog101
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Trog101
    Welcome to NETGEAR Community!
    Do you have the latest firmware (10.13.05.00)? This firmware is known to fix bug issues.
    Blanca
    Community Team
