Noneya
Apr 13, 2025Follower
Project Genesis MR6400 Hotspot
Why is there no support for this device? The one I'm working on for a friend is stuck at the Downloading Software Update screen and will do nothing. When powering on it shows a picture of an ethernet...
Apr 17, 2025Guru - Experienced User
What project Genesis?
How long are you pressing the reset button for? 15seconds then release should do something.
Might try a 30-30-30 reset and see if this could help kick the MR into operation.
Make contact with NG support as well.
