Noneya
Apr 13, 2025Follower
Project Genesis MR6400 Hotspot
Why is there no support for this device? The one I'm working on for a friend is stuck at the Downloading Software Update screen and will do nothing. When powering on it shows a picture of an ethernet...
rcpax
Apr 19, 2025Luminary
you need a compatible power brick with enough amps delivered to the device, a compatible power cable that is adequately rated for it as well.
