and023
Nov 24, 2019Initiate
PSA for Netgear LB2120 using excess 4G Data
PSA: If you purchase a LB2120 and put the device into bridge mode you may see exsessive amounts of data be used. So these 4G modems, when in bridge mode have been reported using exssive amounts ...
and023
Feb 02, 2020Initiate
Yeah, weird. Not too sure what physically changes with the software when you switch between providers, but I wonder if its programmed with some type of network reset while it applies the new profile from the provider? When you change from Optus to Telstra, you would be applying new APN settings, but its likely this would trigger the software to use a new profile during this transition. This profile might be setup with the default DNS settings that I changed above? - Just thinking out-loud. :)
Did you try out the above steps to see if you have any success? I believe you can still set those settings I describe above in both Bridge and standalone modes.
Since posting that initial write up my LB2120 has been going rock solid and have I been using it on and off reliably with my Ubiquiti Edge Router. Good speeds when I need it. :)
Anyway good luck with your!
mallinss
Feb 02, 2020Aspirant
Thanks for the quick response, I’m also using a full Ubiquiti network with there Security gateway device, it works like a treat with the LB2120 in bridge mode, at least with Optus 4g , I’ve had to put it aside for now with Telstra, but I will get it out again and check the settings you mention 😀😀
Regards
Steve
Regards
Steve
