mahalkong
Dec 03, 2022Follower
Questions with Netgear Nighthawk travel router
Hi all, I hope this finds everyone safe and well. I purchased a Netgear Nighthawk M1 router, and couldn't be happier with it. This thing is incredible! I have four (hopefully quick and easy) que...
mli
Dec 05, 2022Tutor
Best to double check the manual for these items: https://www.netgear.com/support/product/MR1100.aspx#docs
1. From memory, the antennas are for cellular signals (I bought this device many years ago and I own many routers so it's easy to get confused, so best to double check the manual to be sure).
2. Yes, there should be instructions in the manual. I've disabled the same.
3. Yes, I do this.
4. Would probably need to check the manual of the WiFi extender you propose to use. I recommend to go for powerline adapters instead to provide a more stable wired connection.
