hakuntata
May 02, 2023Follower
Questions with Netgear Nighthawk travel router
Hi all, I hope this finds everyone safe and well. I purchased a Netgear Nighthawk M1 router, and couldn't be happier with it. This thing is incredible! I have four (hopefully quick and easy) q...
May 02, 2023Guru - Experienced User
1. The external antennas are just cellular. Not wifi.
2. Not aware of being able to turn off the led. But a piece of tape or turning it over works well.
3. If you're leaving it plugged in 24/7, remove the battery. Its recommended
4. An extender should still work with the router. What you can do that I do, is I use a standard router with my hotspot and just put the router in access point mode. The standard router has much better coverage
