Passo53's avatar
Passo53
Initiate
May 18, 2019
Quick Charge 3.0 charger
Is it okay to use Quick Charge 3.0 charger as a power supply for MR1100 router, without battery installed (when used at home)?
Recommendation is to use Quick Charge 2.0 charger. I've learned that QC 3.0 is backwards compatible, but I like to be sure with my MR1100 case.
  • There is several instances on these forums of using quickcharge 3.0 without issue with the MR1100.
1 Reply
  • plemans's avatar
