Doomguy3232
Mar 04, 2023Aspirant
R6300v2 and Nighthawk MR1100 port forwarding issues
i have tried everything from DMZ ( not sure if i did it right though ) to ZeroTier and have been dealing with this issue for YEARS! and now i think its the time that i finally fix it...
Mar 05, 2023Guru - Experienced User
If your using the MR as the host router and modem, why not configure the R series router for AP mode?
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Doomguy3232
Mar 05, 2023Aspirant
though i think it might work, i can no longer get access to my router admin panel and the internet light is orange. i attempted to use static IP to use my PiHole server but it would not work, i still had internet then. then i decided to just use the ISP provided settings and now i have no way to access the panel. the modem panel has all connected devices on the network shown, but without names. the names had shown up earlier.
