vthee007's avatar
vthee007
R7000 firmware question
I've been automatically updating my r7000 firmware and I noticed that there is a new version out... the version that i'm on is V1.0.6.28_1.1.83.  The latest version is 1.0.5.70.  Can someone explain ...
  • TheEther's avatar
    Jul 05, 2016
    Normally, version numbers increase with each successive release and the fixes are cumulative but Netgear pulled all of the 1.0.6.X releases due to bugs.  1.0.5.70 is currently the newest.  If you aren't experiencing any issues, then you can consider staying on 1.0.6.28.  If you install 1.0.5.70, then you will lose Arlo camera support.  If you don't have Arlo cameras, then this won't matter, of course.
