Fhawk
May 02, 2021Aspirant
R7000 Nighthawk no internet no app connection - status offline
After working perfect April 30th 2021 suddenly overnight the R7000 quit working. Since I have a UPC Router as first entry I am still happy to have internet. Is it possible the hardware died some wa...
May 02, 2021Guru - Experienced User
any other led's on?
If you disconnect the r7000 from your other router, then reboot the r7000, are you able to access the GUI on it?
what other router model is it connected to?
