Fhawk
May 02, 2021Aspirant
R7000 Nighthawk no internet no app connection - status offline
After working perfect April 30th 2021 suddenly overnight the R7000 quit working. Since I have a UPC Router as first entry I am still happy to have internet. Is it possible the hardware died some wa...
Fhawk
May 04, 2021Aspirant
44575B7VA02A4
red light Power supply is on all time.
Might it be possible, that the power supply delivers to little power?
michaelkenward
May 04, 2021Guru - Experienced User
Sounds like a good theory. Especially in the light of the manual's section Power LED Stays Amber
If you have another adapter with the same output, try that.
These adapters are generic. Anything with the right output should work. Most of us have an old one lying around!
