emr's avatar
emr
Tutor
Dec 12, 2016
R7100 lock on 4G/LTE
  hi   is there a way of forcing the modem to LTE/4G, i.e. avoiding it to connect to a 3G network?     cheers
  • DarrenM's avatar
    Dec 15, 2016
    Hello emr
    1. Launch a web browser from a computer or mobile device that is connected to the network.
    2. Type http://www.routerlogin.net. A login window opens.
    3. Enter the modem router user name and password. The user name is admin. The default password is password. The user name and password are case-sensitive. The BASIC Home page displays.
    4. Select the ADVANCED > Setup > Mobile Broadband Settings. The Mobile Broadband Settings page displays.
    Here is the settings for the sim card.
    DarrenM
