emr
Dec 12, 2016Tutor
R7100 lock on 4G/LTE
hi is there a way of forcing the modem to LTE/4G, i.e. avoiding it to connect to a 3G network? cheers
- Dec 15, 2016
Hello emr
1. Launch a web browser from a computer or mobile device that is connected to the network.
2. Type http://www.routerlogin.net. A login window opens.
3. Enter the modem router user name and password. The user name is admin. The default password is password. The user name and password are case-sensitive. The BASIC Home page displays.
4. Select the ADVANCED > Setup > Mobile Broadband Settings. The Mobile Broadband Settings page displays.
Here is the settings for the sim card.
DarrenM
DarrenM
Dec 15, 2016Sr. NETGEAR Moderator
Hello emr
DarrenM
emr
Dec 16, 2016Tutor
hi
I'm sorry, my question was not precise enough. I do not have (yet) a R7100. I spare you the long description of the reason, but where I have to install it I need to force the modem to connect in 4G mode, vetoing anything else. I did not know if there was such an option in the setup and I could not find any specific information in the manual.
thanks for the info.
