c3b8's avatar
c3b8
Follower
May 05, 2022
R7100LG error after update Firmware.
Today I have update the Firmware from version 1.0.0.72_1.0.6 to version 1.0.0.76_1.0.8, all update was finished ok. When I restarted the modem LTE it no longer connected to the internet and the Vodafone IT network was not recognized. I try to downgrade the firmware in version 1.0.0.72_1.0.6, the modem works fine. I think the problem was in the new firmware update...???
  • UPDATE August 01, 2022
    I did a factory reset after updating to firmware v 1.0.0.76, and, after waiting for several minutes, the R7100LG managed to connect to mobile network.
    Thank you very much, Bianca O.
  • I have the same problem : when I update the firmware of R7100LG from V1.0.0.72 to V1.0.0.76 the mobile connection doesn't work no more.
    I have Vodafone Italia as Mobile operator.
    • Blanca_O's avatar
      Blanca_O
      NETGEAR Employee Retired
      Hi paolo248,
      Have you tried factory resetting the device after the firmware update?
      Can you please confirm if reverting to the previous firmware version (v1.0.0.72) helps?
      Blanca
      Community Team
    • Blanca_O's avatar
      Blanca_O
      Hi paolo248,
      Thank you for your feedback.  Glad to hear that it's working now.
      Blanca
      Community Team
