dam_ged
Sep 18, 2017Guide
R7100LG Internet via LTE drops out every hour precisely (interrupts video conf calls, games, stream)
Hello,
I have been using the R7100LG for several months without any noticeable issue until I started using video conferencing (Skype for business, formerly Microsoft Lync) on a regular basis le...
- Jul 15, 2018
Hi gbuisson,
Do you have the updated firmware (1.0.0.46) installed?
Blanca
Community Team
dam_ged
Jan 23, 2018Guide
netgear team: this topic has been open for 4 months.
Still NO solution except for a beta firmware which is a partial fix.
Please provide official feedback. This discussion is running in circles.
MikkoFI
Jan 27, 2018Tutor
Hi,
I have the same problem, 4G disconnects and only way to fix it is to boot the device. I also have cheap 4g modem (with terrible quality WLAN..) that does not have the same problem with the same SIM card. I'm contacting the seller and trying to get refund, sadly I'm not convinced Netgear will fix the issue or is even dedicated fixing the issue. :(
- MikkoFIJan 27, 2018Tutor
And I'm running latest firmware. I also tried to disconnect, connect the 4G but no luck, boot is the only way to solve the problem until it disconnects again.
Firmware Version
V1.0.0.38_1.0.6- dam_gedJan 27, 2018GuideElaineM JamesGL ???
Help!!! R7100LG users need follow-up !!!
The link to beta FW doesn't work anymore. Was it withdrawn since it does not contain the lastest security patches??? http://files.netgear-support.com/go/?a=d&i=2AD3JlvTm8- dam_gedJan 28, 2018Guidegamoul
How did you monitor tcp/udp disconnects...?
The only way I have to show see precisely when it drop is to virtual connect to my office desktop via Citrix which freezes upon internet drop out.
Do you have any command line that would help document frequency of dropouts? Thanks
