dam_ged
Sep 18, 2017Guide
R7100LG Internet via LTE drops out every hour precisely (interrupts video conf calls, games, stream)
Hello,
I have been using the R7100LG for several months without any noticeable issue until I started using video conferencing (Skype for business, formerly Microsoft Lync) on a regular basis le...
- Jul 15, 2018
Hi gbuisson,
Do you have the updated firmware (1.0.0.46) installed?
Blanca
Community Team
dam_ged
Jan 27, 2018Guide
ElaineM JamesGL ???
Help!!! R7100LG users need follow-up !!!
The link to beta FW doesn't work anymore. Was it withdrawn since it does not contain the lastest security patches??? http://files.netgear-support.com/go/?a=d&i=2AD3JlvTm8
dam_ged
Jan 28, 2018Guide
gamoul
How did you monitor tcp/udp disconnects...?
The only way I have to show see precisely when it drop is to virtual connect to my office desktop via Citrix which freezes upon internet drop out.
Do you have any command line that would help document frequency of dropouts? Thanks
- gamoulJan 28, 2018Aspirant
I have a permanent IRC connexion that get disconnected every hour.
I also do support with TeamViewer and I get a freeze.
Also if I play online there is a lag for about 10-15s.
But if I leave a ping running, no timeout.- slaskawiJan 29, 2018Tutor
gamoul That's exactly what I was about to suggest. Using IRC (I confirmed this using Konversation and XChat) is the easiest way to reproduce this issue. Just turn it on, sit and wait.
I also ran `ping` and `curl` in a loop to see if this happens also to the new connections. The answer is negative. Pings and curl queries were all successful. Only the established TCP connections are dropped.
Come on Netgear! Now, there is no excuse, you can reproduce it in your own lab!
- dam_gedJan 29, 2018Guidegamoul slaskawi
I am looking for a Windows tool that would graphically show drops (packet loss) frequency.
Command line
https://www.techwalla.com/articles/how-to-check-for-dropped-packets
Wireshark
https://osqa-ask.wireshark.org/questions/5675/how-to-analyse-througput-packet-loss-rtt-rather-than-go-through-the-graph-of-built-in-feature-of-wireshark
Thanks,
Damien
