dam_ged
Sep 18, 2017Guide
R7100LG Internet via LTE drops out every hour precisely (interrupts video conf calls, games, stream)
Hello,
I have been using the R7100LG for several months without any noticeable issue until I started using video conferencing (Skype for business, formerly Microsoft Lync) on a regular basis le...
- Jul 15, 2018
Hi gbuisson,
Do you have the updated firmware (1.0.0.46) installed?
Blanca
Community Team
TowerStudio
Jan 29, 2018Tutor
I wonder if anyone at Netgear is every gonna read this thread and messages again. It's bad. Very bad...
slaskawi
Jan 31, 2018Tutor
TowerStudio dam_ged It seems there is no official Netgear response on this thread (sadly!), so maybe let me give you a small update.
My case (#29651272) has been investigated by the engineering team and qualified as a known issue. I have been told they are working on it. In the meantime I tested a new firmware (V1.0.0.41T1_1.0.6) which was suffering exactly the same issue - all connections were dropped every hour.
So it's been more than 4 months and we do not have any solution. Looking at this thread it seems dam_ged was testing firmware R7100LG_Q1_1.0.0.33_1.0.6_test. So we've had 8 software builds so far (from 1.0.0.33 to 1.0.0.41) without any noticable change. Let's put this straight - if I had known this, I wouldn't have bought this router.
- TowerStudioJan 31, 2018Tutor
I bought this model on Amazon in June last year.
I just sent them an email explaining the situation and asking what they could do to help? Within 5 minutes I got a return form and all I need to do is take it back to the post office, I don't even have to pay for the shipping. If only Netgear treated their customers the same way. I just need to find a better manufacturer (any recommendations welcome). Too bad, the Nighthawk looked nice.
- SteffenHoehneJan 31, 2018Aspirant
Hi guys
I've just changed the this peace of *BAD WORD* with a zyxel lte device. I have no problems so far :-)
6 months of trouble, mobile hotspot and support terror is over.
Netgear - private and business - never again.
Dear guys - just buy another device!
kind regards
Steffen
Ok this is really weird. As I started unpacking the modem, I removed the three antennas and, wondering if the reception was any good without them, I ran some speed test. Then I had other things to do and left everything like this. It's been over an hour and a half and I didn't have any disconnection yet. Guys can you try if it does the same for you? Maybe I'm totally wrong and I missed the disconnection but I've been using the computer since and as I have the modem reset around a fixed round hour so I know when it will disconnect, it should have disconnected 10 minutes ago and definitely didn't... I'll keep an eye open, let me know if that does anything to you.
