dam_ged
Sep 18, 2017Guide
R7100LG Internet via LTE drops out every hour precisely (interrupts video conf calls, games, stream)
Hello,
I have been using the R7100LG for several months without any noticeable issue until I started using video conferencing (Skype for business, formerly Microsoft Lync) on a regular basis le...
- Jul 15, 2018
Hi gbuisson,
Do you have the updated firmware (1.0.0.46) installed?
Blanca
Community Team
SteffenHoehne
Jan 31, 2018Aspirant
Hi guys
I've just changed the this peace of *BAD WORD* with a zyxel lte device. I have no problems so far :-)
6 months of trouble, mobile hotspot and support terror is over.
Netgear - private and business - never again.
Dear guys - just buy another device!
kind regards
Steffen
TowerStudio
Jan 31, 2018Tutor
Ok this is really weird. As I started unpacking the modem, I removed the three antennas and, wondering if the reception was any good without them, I ran some speed test. Then I had other things to do and left everything like this. It's been over an hour and a half and I didn't have any disconnection yet. Guys can you try if it does the same for you? Maybe I'm totally wrong and I missed the disconnection but I've been using the computer since and as I have the modem reset around a fixed round hour so I know when it will disconnect, it should have disconnected 10 minutes ago and definitely didn't... I'll keep an eye open, let me know if that does anything to you.
- TowerStudioJan 31, 2018Tutor
Ok so regarding my comment about removing the antennas, it doesn't "cut" as bad as it did before: it doesn't interrupt my browsing or downloading of files (maybe because the interruption is shorter), but I tried having an IRC window in the back and indeed I am disconnected from the server every hour precisely.
