WDLandry
Aug 17, 2016Aspirant
R7100LG LTE router - Attaching cables for outdoor antenna
Hello, I'm very interested in in the R7100 LTE router to inprove my home network. Are any of the 3 antenna 3g/LTE specific? I am wondering if it is possible to remove 2 of the attached antenna on...
DarrenM
Aug 19, 2016Sr. NETGEAR Moderator
Hello WDLandry
Netgear does not support using 3rd party antennas. And you are correct this is a R7000 with a slot to add your micro sim card for LTE internet.
DarrenM
