dejiko
Aug 13, 2020Aspirant
R7100LG mobile data consuming and traffic meter issues
Hi All, I have a Nighthawk R7100LG and use it in a remote site for IPCAMs with a 4G Data SIM for internet connection. Its all good and works fine but I found the data usage is abnormal. When I ch...
dejiko
Aug 24, 2020Aspirant
Hi, any expert can help?
Some updates: I connected the IP cameras to router (using WIFI only), and it only consumed very little 4G data (see the attachment 1), around 95K packets per day. But at the same time, the WAN has sent 6.6M packets, it consumed 1GB data (attachement 2). Also, I checked the router log and it say a few DoS attack is detected. But I think it should not be the reason for this problem, as I disabled the ping scan from internet, enabling Port Scan and DoS Protection (attachement 3), and I have not set any port forwards, so the router will not responses to any DoS attack, therefore it may consuming the Rx, but my problem contain both Tx and Rx side.
