mireinhofer
Apr 10, 2023Tutor
R7100LG not coming online after firmware update to 1.0.0.78
Hi! My R7100LG is not coming online after upgrading it to the latest firmware version 1.0.0.78. Same happens with 1.0.0.76 and the latest verison that works is 1.0.0.72. In fact, it seems that the r...
Apr 11, 2023Guru - Experienced User
Does it work on any firmware?
did you try contacting the LTE provider to see if the sim card needed to be authorized again?
mireinhofer
Apr 11, 2023Tutor
It works with firmware version 1.0.0.72, please see pictures above. Sim card does not need reauthorization.
- plemansApr 12, 2023Guru - Experienced User
Might be your ISP doesn't allow a hot swap of sim cards and the firmware change causes it to look like a different device.
That's why I mentioned having them re-authorize. I can see 1 version of firmware having a bug but if all the newer ones do, it makes me wonder if the ISP is picking it up as a different device.
- mireinhoferJun 25, 2023Tutor
Okay, thank you for elaborating. The thing is, I am able to use the SIM in another device (surf-stick) and it connects without a problem. So I assume that the carrier does not mind if the device changes. Anyway, I will continue to use the R7100 a while longer with an older firmware.
