dahisser
Apr 03, 2018Aspirant
Range Extender recommendations for MR1100
Wondering in anyone in community has range extender / mesh network recommendations for use with the Nighthawk MR1100 to broaden it's coverage area? Good results? What to avoid? Netgear tech support s...
JSchnee21
Apr 03, 2018Virtuoso
Hi dahisser,
I’d suggest a proper wireless access point plugged into the Ethernet jack. Something like the TP-Link EAP245 (or 225) or similar non-router. Steer clear of the EAP330 (it’s flaky). If you get a small switch like the Netgear GS105 or GS108 you can connect a number of devices (like Roku, PC, etc) in addition and save loading your Wi-Fi network with streaming. Turn off the Wi-Fi on the MR1100, get a decent QC2/3 rapid charger (Anker) and run the MR1100 without the battery installed.
-Jonathan
-Jonathan
