dahisser
Apr 03, 2018Aspirant
Range Extender recommendations for MR1100
Wondering in anyone in community has range extender / mesh network recommendations for use with the Nighthawk MR1100 to broaden it's coverage area? Good results? What to avoid? Netgear tech support s...
UK-based
Apr 04, 2018Luminary
And if you need wider coverage, you could wire an Ethernet switch to the MR1100 and then wire multiple access points to the switch. How you decide to do this depends on your budget and your willingness to try things out. I wanted a low-cost solution so I bought this low cost TP-Link 5-port unmanaged Ethernet switch. I then purchased two second-hand routers and set them up as access points, disabling their DHCP services and firewalls. I gave them different SSID names, including naming the 5GHz and 2.4GHz bands differently so that I always know which router and which speed my devices are connected to. There are plenty of YouTube videos that can help with this. I kept the WiFi active on the MR1100 to give me an extra zone of WiFi signal. The MR1100 is running without battery on an upgraded charger, as indicated by JSchnee21.
The only occasional problem I get with this setup is that if a mobile device (Android tablet in this case) is connected to one of the access points and I then move into the zone of the other access point, the device attempts to connect but sometimes doesn't receive a new IP address from the MR1100. It just displays "Obtaining IP address". I've found a few ways around this - switching off the access point forces a new IP address to be allocated, but this isn't an ideal solution, especially if the access point isn't very accessible! I've also found that connecting the device to another router (I've got a landline router in addition to the MR1100) and then back to the problematic access point does the trick, but many people won't have this option. I think I may have also got around the problem by connecting directly to the MR1100 and then back to the troublesome access point. I may also have tapped the power button on the MR1100 as a last resort. I'd have to confirm the latter 2 solutions when they crop up again.
I don't know what causes this inability to obtain an IP address from the MR1100 when swapping from one access point to another, so if anyone can explain this I'd be very grateful. Is the fault with the MR1100?
- nhantennaApr 04, 2018Apprentice
"swapping from one access point to another"
traditional wifi + automatic swapping/switching between ap's is hit or miss. your end device (android tablet) is managing the connections. each end device can behave differently (tablet vs phone vs laptop etc). user experience is bad. my recommendation, manually connect to the ap you are near.
if you are serious about automatic swapping/switching between ap's, mesh networks is what you want. in mesh networks the mesh ap's control the connections (NOT the end devices like android tablet). As you move around house/office the mesh network itself moves you from ap to ap. better experience, not perfect, but way more expensive then traditional wifi ap's.
on my nighthawk lte hotspot, i have never had any trouble manually connecting to a nearby traditional wifi ap.
i have nighthawk wifi turned off. overall bad experience. in the nighthawk's defense there is a limit with what you can do with such a tiny device with tiny internal antennas. the nighthawk lte hotspot can not compete with a traditional wifi ap performance/range/experience-wise.
- UK-basedApr 05, 2018Luminary
nhantenna: thanks for suggesting a possible cause of the problem I'm having when moving from one access point to another and for introducing mesh networks.
I should have been more explicit in my explanation. I do indeed attempt to connect manually to the second access point by specifically selecting its SSID. At that point I can no longer see the SSID of the first AP because I'm well out of range, and I'm only a couple of feet away from the AP I'm connecting to. More often than not, I get the message "Obtaining IP address" without any subsequent internet connection via the MR1100. That's why I'm thinking that the problem lies between the MR1100, the unmanaged ethernet switch and the access point, with the most likely cause being the MR1100.
Do you have any other thoughts on this?
- dahisserApr 05, 2018Aspirant
Big thanks for the responses, dialog and counsel...greatly appreciated! Had actually purchased Anker rapid charger per recommendations in other discussion threads. Hooked it up and removed the battery.
Confess that I'm fairly low level tech savvy and have household/home-office filled with low tech users so whatever will be most "user friendly/tech light" will be the direction I'll ultimately go. Frankly while mesh may be more costly, sounds like it could be simpleist to deploy and least complex for users/devices? Am I reading that correctly?
Any experiences with NETGEAR Nighthawk Mesh X6S Tri-Band WiFi Mesh Extender? Other Mesh tech/models?
thx!
