intoxicthreat
Feb 20, 2020Follower
broadband disconnected
Today I woke up to my Broadband disconnected again. Some of the issues reported already never really gave a clear answer on how to fix this issues. If T-mobile is really blocking the connection to my...
melwiththecell
Feb 22, 2020Guide
I had my ISP guy have another customer try this and it seems to have worked for the time being. Add another APN. APN Name "broadband", APN "broadband", PDP "IPV4", then none and none. I'm trying it now.
melwiththecell
Feb 22, 2020Guide
broadband/broadband in APN didn't work. Tried activated att sim and tmobile sim. Neither worked. This is a confirmed Netgear issue! Why?
- JohnPengFeb 23, 2020NETGEAR ExpertSorry, I misinterpreted the issue. We released an update fw to address the broadband discussion issue on Feb 13th. Please do a manual upgrade check to upgrade your device to the latest release.
Thanks- melwiththecellFeb 23, 2020Guide
Might you be able to recommend how it can check for an update when it isn't getting service? Please proved the download link.
