MyNightHawkM2
Sep 24, 2021Follower
Can NightHawk M2 provide Wi-Fi when connected to the internet via an Ethernet wall jack?
Hi: I am about to purchase a NightHawk MR2100 and would like use it at work, too. But at work the Wi-Fi router will be connected to the internet through the Exthernet wall jack. So, here ...
ArodiD
Sep 27, 2021NETGEAR Expert
Hi MyNightHawkM2 ,
You can use the Ethernet Offloading feature to obtain connectivity via the wall socket and use the MR2100 as a WiFi access point. Once you disconnect from the wall socket(if ethernet offloading is enabled) it will fall back to using the mobile network.
Arodi
