sayed1997
Oct 27, 2017Tutor
Can't Update firmware of my Netgear MR1100
Hi there ..i got Unlocked Telstra Nighthawk M1 (MR1100) and currently it running under Sim card of Zain Kuwait ....my current Frimware is NTG9X50C_10.12.02.01 which is back on 2017/01/28 ...every ti...
windofage
Apr 24, 2018Initiate
Hi, JasonN,
It seems all 3 options doesn't work for me.
Option1: App gives me an error dialog after I click "CHECK FOR UPDATES"
Option2: There is no manual upload option cause my firmware is old.
Option3: The blue button freezes at "CHECKING..." after I click "CHECK FOR UPDATES".
JasonN
Apr 27, 2018NETGEAR Employee Retired
Hi Mored1984,
Thank you for your response. I will PM you for further assistance on this. :]
- Jason N
