Sawman27
Feb 14, 2020Aspirant
Double NAT on xbox
Trying to play Xbox live and it’s saying I have a double NAT and a strict NAT. I only have the nighthawk hot spot. No router. I just need some guidance! Like Ethernet to the hotspot?? Orrr??? Anything...
Ksa3344
Feb 18, 2020Apprentice
Have you tried changing DNS manually to Google DNS ?
Primary : 8.8.8.8
Secondary : 8.8.4.4
Primary : 8.8.8.8
Secondary : 8.8.4.4
Sawman27
Feb 18, 2020Aspirant
I changed it and still double NAT and strict NAT. I have no clue. This is gonna be the death of me...
- Ksa3344Feb 19, 2020ApprenticeWhat about the LTE band ?
Try to fix each band and see if it works.
i used to have this problem with one specific LTE band with PS4 , when i fixed another band the problem vanished.
so check all the supported bands by your carrier and try them separately.
another thing , move the sim to your phone and tether from it and check if you still have the problem.- Sawman27Feb 20, 2020AspirantHey man I have no clue what any of that means let alone get to it to check any. I’m going to just have to find somebody here to physically come to my house and see it and try and fix it. I’m sorry. You’ve tried way to hard to be a random person. Thank you very much tho. This sucks.
