mackov83
Mar 23, 2020Star
LB2120 with external antenna
Has anybody ever attempted to use an external antenna with this device? I live in Sydney Australia and am ~800m from my closest tower. I bought this external MiMo antenna to try and boost my signal -...
mackov83
May 16, 2020Star
LlamaLarry apologies, I had not seen your message until Sheaj544 responded. I bought the Huawei B525s-65a and went through a process and installed what's called the 'factory' firmware. This gives you access to features that most telcos block from use - i.e. bridge mode, band steering etc. Sheaj544 if you are on Optus, I'm guessing you likely have the locked down version of this exact device!
You can get them on eBay or GumTree second hand for anywhere from $50 (I wouldn't spend more than $150 or so). I saw many people stating in their ads they 'no longer needed it because they upgrdaded to NBN'. Unfortunately, vendors, telcos and NBN are misleading the public with marketing BS. With LTE (unless directly under a tower) will never get the advertised speeds without a high gain external antenna.
To be fair, I did end up testing the Nighthawk M2 and got similar speeds to the Huawei, but the LB2120 never came close. It does not support carrier aggregation whatsoever. Also, while the M2 marketing suggest speeds of 1gbps, it is highly unlikely you would ever reach that either.
Also, Sheaj544 , by the sounds of it you are also in Australia. Therefore I would highly recommend checking out:
1) rfnsa.com.au. This allows you to get details on the local towers nearby, as well as it's capabilities - freq, throughput etc. My nearest tower is 800m away. Keep a lookout for the 'cellID'
2) Aus Phone app - allows you to get a good idea of what bands are reaching your location the strongest, and focusing on them
mackov83
May 16, 2020Star
BTW, I am also using a directional antenna - which as the name suggests focuses its energy directly at the tower. I am interested to hear how others have got on with omni-directional, as this would be easier to setup.
