mackov83
Mar 23, 2020Star
LB2120 with external antenna
Has anybody ever attempted to use an external antenna with this device? I live in Sydney Australia and am ~800m from my closest tower. I bought this external MiMo antenna to try and boost my signal -...
Sheaj544
May 17, 2020Aspirant
Appreciate the reply mackov83. Wise choise with the 5G antenna, It seams this is the way forward with NBN alternatives. My setup includes am omnidirectional antenna, which seams to do the job well. (4G bands only :Z) Guess ill be on the hunt for another modem as the lb2120 cant seam to do the job. Ill post the specks/ model if it interests you.
As a way of overkill the new project after 1 year of stable operation with one LB2120, is to have 2 LTE modems fed from the one antenna, my means of antenna splitter/cominers this seams to be achievable, however I have yet to begin testing. What current speeds are you getting with the new setup ? are the uploads better than the single digits you where getting earlier. As stated above the LB2120 isnt all that bad if by chance the stars align. 100/40 is sean most days with Vodafone. RSRP -88 which I guess is a good signal strength.
Also thanks for the RFNSA suggestion, when i was designing this system this time last year I found a real usefull site like this however cant seam to find it now. Will be usefull to keep an eye on 5G rollout. While not an early adoper at this location in Melboune with no ADLS and unstable NBN im ready to test even better speeds. :o To give Optus props seams they have a reasobale deal with unlimited 5G, fingers crossed its still around when there is coverage in my area.
mackov83
May 17, 2020Star
Let me know how you get on using the same antenna for two connections, but I have a feeling that won't work. Likely you will end up with some level of contention? More than happy to be proven wrong though :)
Originally I was testing with the Optus SIM from my phone and it seemed to give better upload speeds. My NBN provider has a month to month SIM for $35 for 30GB that can pool data up to 100GB which was enough as backup internet - has saved me a few times. But it only does 6-7mbps uploads. I did muck around with telstra.extranet APN (which is supposed to be for businesses) and that seems to give a more symmetrical service, but the download speeds take a hit.
BTW, for anybody reading this it is best to test max throughput after 11pm/12am to get the max values, and comparing those to times of high use - i.e. 7 or 8pm.
