d4bbott
May 01, 2024Aspirant
M6 not connecting to 5G
MR6110-1A1NAS. HW Version 1.0 FW Version NTGX65_10.01.22.01 All cellular devices in my household recognize the 5G cellular network. My Nighthawk M6 will not allow the 5G settings for the APN. It a...
- May 09, 2024
I broke down and took everything to a local AT&T store. They confirmed that I had done everything right, the device is a 5G device, and I have 5G service where I live. They also confirmed that this was not the first time they had heard of such an issue. Turned out to be a SIM card issue. They took a new SIM card, provisioned it to a 5G device in the store, installed it into the M6, and now I have 5G service with my hotspot.
W1lliam
Jun 19, 2024Virtuoso
MR6150-100EUS(NSA/SA), MR6450-100EUS(NSA/SA +WiFi6E) or MR6550-100APS (NSA/SA+mmWave+WiFi6E)
Ir you can take previous generation, M5, MR5200-100EUS (only supports NSA so far)
A99Problems
Jul 02, 2024Aspirant
Hello, can you please help me with a information ?
I got a Netgear M6 Pro, model MR6450-100EUS , but I'm not getting 5G connection , I tried all the prepaid networks available in Romania .
Any idee why ? Or how to fix this ? It should be working right ?
- W1lliamJul 02, 2024Virtuoso
JohnPeng maybe there is something need to modify for NR5G at Romania
Please do check with the carrier for such prepaid sim card if
1. they can be used with hotspot
2. APN settings is done correctly to enable the service
- A99ProblemsJul 03, 2024Aspirant
I did checked the APN , its the same as on my phone, and my phone it's showing 5G connection , APN good everything good but no 5G connection on my Netgear M6 Pro device .. strange right ? What could that be ?
- W1lliamJul 04, 2024Virtuoso
if APN has no issue, then you need to check if that sim card does support hotspot usage
- JohnPengJul 10, 2024NETGEAR Expert
Please send me a model.jsonf file with the SIM card inserted.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backYou can send PM to me and mention your community ID.
Thanks
