Steve1001
Mar 28, 2023Aspirant
MIFI MR1100 and AC815S Setting APN
The two new service providers I have Sim cards for require that I set my MiFi APN to get their service. Currently I have no service on either MiFi, so I can't login to the wifimanager to change or ad...
Steve1001
I should mention that both had previous service plans. The MR1100 still is locked, but the AC815S is unlocked because I could do that from the device. I'm not sure if a factory reset would help because this is more of a connection issue I think?
- JohnPengMar 28, 2023NETGEAR Expert
If you are trying to log in to WebUI, the default log in password is printed on the product label.
If the password get changed and you didn't know it, you can do a factory reset to restore the default admin password.
Thanks
