Teewee4134
Sep 29, 2017Guide
MR1100
On the LCD screen of the Nighthawk M1 Show 4G but am surprised its not showing 4G+ Has anyone ever seen 4G+ on their MR1100?
- Nov 14, 2017
Hi Teewee4134
If you are using the Telstra MR1100 then you will never see 4G+ RAT icon as this was never implemented on this SKU. The only way you can determine your device is doing carrier aggregation is if you are seeing over 150Mbps on the downlink.
Kind Regards,
ArodiD
TeeJay74
Oct 02, 2017Virtuoso
Because of security policies have been tightened up lately, telnet cannot be used anymore( port is closed). However there is still a way to use AT-commands. I think you should send a private message to some Netgear Community Experts to get more help. Or they may have an alternative solution for your problem.
Teewee4134
Oct 02, 2017Guide
Thanks
